BrewCrew34
May 28, 2019Initiate
Router sending signal but every device says no internet connection
This morning I woke up to my phone, computer and other devices saying they were connected to my network but had no internet connection. I restarted the modem and router multiple times and the result is still the same. I tested to see if the modem was working by connecting it directly to my computer via an ethernet cable. The internet worked fine proving that it was the router having the issues. I also tried multiple different ethernet cables to see if that was the issue and it was not. There was a storm last night and into today so I thought that could maybe be the issue. But the internet worked fine when directly plugged into the modem so it doesn't seem to be that. I'm not sure what to do from here and hope someone can find me an answer. Thanks!
- I discovered the answer after more troubleshooting. I saw in my router settings that I had a static IP selected. I switched it to "get dynamically from ISP" and my internet worked instantly. I posted this reply to prevent people from helping me troubleshoot and to hopefully help someone in the future.
- BrewCrew34InitiateI discovered the answer after more troubleshooting. I saw in my router settings that I had a static IP selected. I switched it to "get dynamically from ISP" and my internet worked instantly. I posted this reply to prevent people from helping me troubleshoot and to hopefully help someone in the future.
- myerswMaster
Do you know if this was after a firmware update?
Maybe one during the night that changed this setting?
Thanks for posting the fix as someone else may have the same thing.
