Reply
Router
hbhoyle
Follower
Router
I bought this router in January and could login to manage parental controls and other various things. But just tried to login throught the Genie app and am redirected to the Nighthawk app. There is virtually nothing i can do with it. It lets me login but there is not anything i can control. Particularly, Parental controls. Not sure what to do other than throw the thing in the trask and get a Linksys.
Model: R6120|AC1200 Dual Band WiFi Router
Message 1 of 3
JoseAndres041
Luminary
Re: Router
You can still use Desktop Genie to configure Parental Control. Your NH app could do:
1. remote management
2. speed test
3. configure wireless settings
4. reboot the router
5. check for firmware update
6. Pause/Resume internet per device
7. WiFi analytics for signal strength
8. Configure Traffic Meter
9. Configure Guest Network
10.Help you install your router for internet connection
11.Account Management for your Netgear account
12.Your device's support contract
13.Enabling Circle
14.Enabling Armor
If you don't use these things then you could throw your device or phone away.
Message 2 of 3
DexterJB
NETGEAR Moderator
Re: Router
Hi @hbhoyle, welcome to the community! As suggested by JoseAndres041, you can still ustilize the desktop Genie. You can download it on the link below.
https://www.netgear.com/home/discover/apps/genie.aspx
Dexter
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 268 views
  • 0 kudos
  • 3 in conversation
Announcements
