Reply
Routerlogin.net Advanced Tab not loading in Safari (macOS Sierra)
RTCanada
Just wondering if this is a slight glitch in the programming? Ever since updating to the new firmware from my R7000 (V1.0.7.10_1.2.3) I cannot access the advanced tab page for my router settings on Safari. The entire page's alignment is all off and none of the corresponding menus are loaded on the left hand side.
- Going through Chrome has no such problems. As well as loading in Chrome on my desktop PC that is connected to the Netgear.
- Odd thing is using my iPhone 7 safari application provides no such errors leading me to believe this is an error in the page loading on the desktop version of Safari.
Can anyone replicate this? I've tried clearing the cache and restarting the browser and to no avail. Not a big problem since I can use Chrome if I need to change settings, but a bit of a nuisance nonetheless.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
LeeH
Prodigy
Re: Routerlogin.net Advanced Tab not loading in Safari (macOS Sierra)
Many problems can be created when firmware is changed.  The fix is to reset the router using the reset button on the back held in for about 10 seconds.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3168 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
