Reply
Routerlogin.net Not Secure
JNGR2018
Tutor
When I go to log into routerlogin.net, my browser warns me that the connection is not secure. I type "https" before the aforementioned web address, but that doesn't work. Is this all normal? is it normal for the routerlogin.net to be an unsecured connection, or is that something I should be worried about? Thanks!
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
shamarin
Virtuoso
Re: Routerlogin.net Not Secure
It's normal because secure connection is not supported in Netgear Nitghthawk serious of products. Secure connection (via https) to router GUI is under engineer investigation from 2017, maybe we will get it soon.
Message 2 of 4
antinode
Guru
> [...] is that something I should be worried about?
   Presumably, you're talking to your own gizmo on your own LAN.  If
someone can overlisten to that traffic, then you're already in big
trouble.
Message 3 of 4
JNGR2018
Tutor
Okay got it. Thanks everyone!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4023 views
  • 3 kudos
  • 3 in conversation
Announcements
