- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Routerlogin.net - constant password recovery
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
EVERYTIME I try to log in (routerlogin.net) I have to use password recovery. My username and password is correct.
I log in... password recovery. If I log out and log in again 10 minutes later.... password recovery!
There has to be e batter/easier why to access the router.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@zambeezi wrote:Hi,
I just bought a Netgear and found this to be annoying also. I found a solution:
1. after logging in go to the Advance tab
2, select Administration on the left
3. select Set password
4. uncheck Password Recovery
5. problem solved
6. you'll get a warning about needing to restore to factory default if you can't remember your p/w.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
@zambeezi wrote:Hi,
5. problem solved
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Routerlogin.net - constant password recovery
Perfect, thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great! Glad I could be of help....
