Reply
Routerlogin.net - constant password recovery
Whosam
Currently I am trying to configure my brother router nighthawk X6 R8000 , I did rest and it did as manual said flashing all light and reboot , browse routerlogin.net , asked for password ( used the default admin and password ) then next page is question which I don’t know the answer , obviously and my brother can’t remeber , currently I can’t access the WiFi or the setup page ,
I read many people get stuck in recovery mode as no one knows the answers for none sense questions , please someone give me solid solution , many rest did not wipe the whole configuration and recovery question never went away .
Your response will be much appreciated as I am not using my home internet and using my 4g Mobile instead , My first experience with Netgear and hope will be good , I used Linksys and tplibk as well dlink ( rest button always do the job from first time )
Regards
Sam
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
schumaku
Guru
Re: Routerlogin.net - constant password recovery
Some older Nightawk models and firmware send the user to the password recovery questions - even if never configured before - after entering a username and specifically an invalid password.
What's wrong with doing a complete factory reset - are there potentially access credentials and tunneling config (ie. PPPoE) stored for the ISP access?
Message 2 of 4
Whosam
Thank you for assisting me , how I can do Full factory rest , I used paper clip and pressed the rest Botton in the back on the router for 10 Second till it’s blank and rebooted .
How to do it as I have nothing to worry about now except to setup it from beginning with WiFi credential and security .
Is there any way to upgrade firmware without accessing the router ( setup page )
When I restart the router , Netgear 5g guest appear fo 1 min and then disappear!!!!
Really wish I can solve it and access internet at home Instead or using my mobile like ice age .
Regards
Sam
Message 3 of 4
DarrenM
Sr. NETGEAR Moderator
After the factory reset you will need to configure the router again you will want to connect a PC via ethernet cord to the router and then go to www.routerlogin.net then enter admin/password to log into the unit there you can rename the wireless and give it the password you are wanting. Also you can upgraded the firmware.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2010 views
  • 1 kudo
  • 3 in conversation
Announcements
