Reply
SNMP Community String for Nighthawk R7000
Hello,
I'm looking for a way to get a SNMP Community String for my Nighthawk R7000 so I can use a network monitoring tool.
Dows anyone know how I can do that or if this router supports that?
Thank you,
EFillF
Message 1 of 7
Master
Re: SNMP Community String for Nighthawk R7000
Nothing in stock firmware.
Message 2 of 7
So there would be no way to add this router to Spiceworks?
Message 3 of 7
Master
If you can find a hack into the firmware, you may be able to pull it off. Otherwise, look at a third party fw that supports SNMP. Good3rdPartyfw  - I run my R7000 with this firmware in AP mode, but I think Xvortex firmware in router mode supports SNMP. If not, I'm sure you could add some sort of script for it.
EDIT: Yup - just found it, SNMP tab in Xvortex FW, on Admin page..
Message 4 of 7
Master
Xvortex SNMP and Spiceworks works. Loaded it up no issues.
Message 5 of 7
Do you know if DD-WRT would allow me to do it?
Message 6 of 7
Master
I don't folllow DD-WRT
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 7354 views
  • 1 kudo
  • 2 in conversation
Announcements
