- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SSH go through R7800 directly
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm new to Netgear router. I started to use R7800 last month with latest firmware 1.0.2.28. I set up 3 port forwarding rules (HTTP, FTP & L2TP/IPsec) on the router to access my internal machine. However, I found a lot of SSH traffic went through my router keep trying to login my internal Linux machine recently. Dose anyone has similar issue? How to block all incoming traffic except HTTP, FTP & L2TP/IPSec to my internal network?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very unlikely the Nighthawk would allow incoming connections on 22/TCP to your Linux system on the LAN on it's own.
Only TCP and UDP ports forwarded manually or by UPnP PMP/IGD are permitted to access the mapped port on the LAN IP address. Check your router on Advanced -> Advanced Settings -> UPnP ...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
