Reply
SSID Problems
Noble-One
SSID Problems
Firmware Version:  V1.0.9.60_10.2.60
Since updating to the above firmware, unchecking "Enable SSID Broadcast" also disables "Enable Wireless Router Radio."  This was not the case prior to the firmware update.  Has anyone experienced this and if so, do you have a solution?
I prefer to not broadcast our SSID for security reasons, but now our router radio also does not work without SSID being enabled.  Any help please?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
myersw
Master
Re: SSID Problems
There are lots of issues with the .60 release. Suggest reverting to version that was working for you and wait for a fix.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 5
Noble-One
Re: SSID Problems
Thank you.  I will check to see if I still have the older version.  If not, do you have the file or know where I can find previous firmware versions?
Message 3 of 5
Noble-One
Re: SSID Problems
Thank you again.  I found the previous firmware version.
Message 4 of 5
myersw
Master
Re: SSID Problems
It is possible you may need to reset and reconfigure, but only if things are still not working after the downgrade.
--Bill
Tesla > Edison
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 388 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
