Orbi WiFi 7 RBE973
Reply
Same Router use as Extender Nighthawk ac3200
Chandansatpola
Hello all, i have purchase 4 Wifi router i.e.  Nighthawk x6 AC3200 r8000, and i want to connect eachother as a extender,  my first router is my main router and all others are connect to it vai a     gigabyte  switch.
all are working fine...but i want to know, should i have to change the channel for both 2.5 and 5ghz frequency. or i should kept them same as it was...
if i kept them same...will it make disturbance  in wifi range?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 8
Accepted Solutions
antinode
Guru
Re: Same Router use as Extender Nighthawk ac3200
> [...] All are wireless devices. Only access points are connecte with
> wires.
   And that's the reason.  The access point itself sees a wireless
connection, but the router sees only the wired connection (from the
access point).
   When a wireless device connects to the router's built-in access
point, the router knows that it's a wireless connection; everything else
is a wired connection (so far as the router knows).
Message 8 of 8
All Replies
antinode
Guru
> [...] i want to connect eachother as a extender,  my first router is
> switch. [...]
   "gigabit" switch, but what, exactly, does "extender" mean to you?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Use the Router as a
Wireless Access Point".
> [...] should i have to change the channel for both 2.5 and 5ghz
   I'd expect better results (less interference) if nearby access points
used different radio channels.
Message 2 of 8
Chandansatpola
yes, i use them as a access point ...
should i use same channel for all routers?
Message 3 of 8
antinode
Guru
   Still true.
Message 4 of 8
Chandansatpola
I have 1 main router and 11 ( access point router) same model.
i used same config for all routers....i.e same ssid, password, and same channel also.
but the problem is my 2.4 ghz signal are weak...signal can't break 2 walls..signal goes to zero.
channel for 2.4 ghz is Auto
channel for 5ghz (1st band ) 36
channel for 5ghz (1st band ) 149
channels are for all 12 routers
any suggestion..
Message 5 of 8
antinode
Guru
Message 6 of 8
Chandansatpola
I got your answer...thanks for help
One more questions.
Users are connected to my access point but they are showing as wired connect ,not showing in 2.4 ghz band and 5 ghz band..
All are wireless devices. Only access points are connecte with wires.
Message 7 of 8
antinode
Guru
> wires.
access point).
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1826 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
