- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Samsung TV does not show ReadyCloud
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I have tried to troubleshoot this for a while but I can't seem to find a solution. My Samsung TV will now show ReadyShare as a source. On the contrary, I am able to access the USB through \\readyshare and also through readycloud web portal.
The USB is detected when I logged in through routerlogin.net
The router firmware version is V1.0.9.88_10.2.88
Any help would be appreacited.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You put the R7000P in your signature but your firmware is for the R7000?
Which do you have?
Are you trying to stream off your router to your tv? Most tv's require a dlna server to do this. The most recent firmware (that your on) had the dlna server removed as well as itunes server, downloader, time machine, kwit, and tivo. It was removed so Netgear could add Armor.
You can downgrade the firmware if you'd like to get those functions back.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which do you have?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Samsung TV does not show ReadyCloud
It used to work just fine before the update so that explains everything.
Are there specific instructions on downgrading the firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
downgrade over a hardwired connection and factory reset afterwards. I'd also probably do a manual install (not from backup).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The prior version.
The most agreed upon stable version that most use is .42 though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if you have further issues and we're happy to help!
