- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Second 5 GHz radio
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Second 5 GHz radio
My 2.4 GHz (2.4GHz b/g/n) is enabled and works fine
My first 5 GHz (5GHz-1 - 2.4GHz b/g/n) is enabled and works fine
My second 5 GHz (5GHz-2 - 2.4GHz b/g/n) is enabled and is not visible from any mobile device. SSID Boradcast is enabled. I tried manual setup without success. Tried changing chanels (149, 153, 157, 161). It worked fine in the past.
Model: R8000
Firmware: V1.0.4.52_10.1.67
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Second 5 GHz radio
Are you using smart connect?
Have you tried a simple factory reset and reinstall?
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@plemans wrote:Are you using smart connect?
It seems that it started several firmware updates back. I did not pay attention and I did not notice it up until recent firmware update.
I do not use Smart connect. I did not try the reset yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Netgear added Netgear Armor after veresion 1.0.4.28. Some devices needed a reset and manual reinstall after armor was added. some actually needed to be downgraded. I'd try the reset first. If that doesn't fix it, then try downgrading to the version I mentioned above.
