Reply
Highlighted
Follower
Security Settings when in Access Point mode
Hi
We are using our router in Access Point mode. Can anyone advise the appropriate security settings to utilise.
It has defaulted to WPA2-PSK
We are on firmware Version V1.0.9.88_10.2.88
Thanks
Peta
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Highlighted
Guru
Re: Security Settings when in Access Point mode
> [...] Can anyone advise the appropriate security settings to utilise.
   What would you use if the R7000 were configured as a router?
   If you're using some other wireless router, then I'd configure the
wireless security on the R7000-as-WAP the same as it is on that main
router.
   Not everyone's favorite.
Visit http://netgear.com/support , put in your model number, and look
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and, especially
for a topic like "Manually Upload Firmware to the Router".)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 181 views
  • 0 kudos
  • 2 in conversation
Announcements
