Reply
Security VU 582384
air-D
Security VU 582384
Does this security advisory apply to Nighthawk R6900 ?
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: Security VU 582384
Message 2 of 5
All Replies
Guru
Message 2 of 5
All the firmware for this security update is now out of beta.
Now that it is officially released, the new version should show up if you tell your device to look for firmware updates.
  • Administration
  • Router Update
  • Check
Or download and apply manually by following the links in StephenB's message.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 5
air-D
Just did the firmware update last night
Message 4 of 5
air-D
* router login, advance, router update, check
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1961 views
  • 0 kudos
  • 3 in conversation
Announcements
