Reply
Security questions
Dvangord
Follower
Security questions
Hi, I am trying to get into my router and every time I put the security question answers in, it is telling me they are incorrect. I’ve tried resetting the router to factory and it still is asking me the same security questions after I factory reset. Help!
Message 1 of 5
Re: Security questions
Which router is this?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 5
tlmassey
Apprentice
On the back of your router there should be a small paperclip-sized hole with a button inside.  Insert a paperclip to hold the button down for a solid 10 seconds.  This will wipe any settings on your router, including password and security question information.  Then you should be able to log back in with the standard admin/password combination.
Message 3 of 5
Randal255
Just call it's easier
Message 4 of 5
Not if no one out there knows what these security questions and answers are. And good luck find a number to call.
These are set up by the user, not by Netgear. Anything Netgear creates is on the back of the device.
But as the person who asked the question has gone to earth, it is anybody's guess as to what they are talking about.  Maybe they fixed the problem and haven't got round to telling us.
So far, @tlmassey has provided the best advice.
Just another user.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5348 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
