Reply
Serious stability issues remain - why are firmware releases far and few between?
NetGearHead5
Guide
There are serious stability issues remaining with the X6 and yet we haven't seen a new firmware in several weeks.
If I do sustained file transfers wired or wireless, the router just simply gets unstable and all wireless connections in my home will just "wink out" for a period of time. All of them drops. All of them. Last night, it got so bad that I tried to remotely recycle the router twice with the Genie app and eventually just had to power-cycle the router to get it operating correctly again.
Generally, the only way I can manage this is to recycle the router every other day.
Message 1 of 2
Retired_Member
Not applicable
Re: Serious stability issues remain - why are firmware releases far and few between?
Not disagreeing with you at all. Have you tried using a switch to avoid running wired through the router when transferring between two wired devices. I do and I transfer over 4TB several times a month without a problem.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6621 views
  • 0 kudos
  • 2 in conversation
Announcements
