Reply
Set up problem
KarenJ67
Follower
Set up problem
I just purchased the Netgear Nighthawk R7000/AC1900 and cannot set ip up.  I have reset it multiple times and the router remains hidden from my WIFI list.  I can see one Netgear Product but its not the one I am setting up.  I have deleted my browsing history multiple times and cannot get onto Routerlogin.net
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
microchip8
Master
Re: Set up problem
have you tried http://192.168.1.1 ?
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 4
antinode
Guru
Re: Set up problem
> up. [...]
   "cannot" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> [...] the router remains hidden from my WIFI list. [...]
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Top and Front
Panels" and "Table 1. LED and button descriptions".
   What do the LED indicators indicate?  Did you press the "WiFi On/Off
button with LED"?
Message 3 of 4
Re: Set up problem
What is the modem in front of this router?
Apart from the wifi issues, have you persuaded it to connect to the internet?
As to getting at the thing, check this:
If you cannot login to your router | Answer | NETGEAR Support
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 332 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
