- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Set up
- Mark as New
- Bookmark
- Subscribe
- Permalink
Set up
I am in Canada. I just purchased mode AC1200 Dual band wifi range extender. Unable to set it up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Set up
What extender is it? AC1200 is a speed
What router are you connecting it to?
Are you installing using wps?
Where is it failing in the process? Since we aren't there we need details to better help you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Set up
@Scartier wrote:I am in Canada.
That's nice, but does not help a lot here.
@Scartier wrote:I just purchased mode AC1200 Dual band wifi range extender.
If you don't have the quick start guide at hand, head to https://netgear.com/support - in the input field type the model number designator for your device. this starts e.g. with EX - there are many different models.
Select your model, click on [Documentation] and download both the Installation Guide and the User Manual. Spend some time to study. Follow the advise of the Installation Guide.
Tell us exactly what you do, what you try to do, what you see, and what you get.
@Scartier wrote:Unable to set it up.
Unable to help based on the information supplied.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Set up
If this is a new device, Netgear does provide 90 days complimentary support. -> https://www.netgear.com/support/contact.aspx
