Orbi WiFi 7 RBE973
Reply
Setting either 5 or 2.4 mghz for devices
CDBART
Follower
hello
just wondering if there is a way to tell the router which band (2.4 or 5) to use on selected devices.  My tv loads on the 2.4 .   My microwave is close to tv and stops streaming when it is in use so i need tv to be on 5 mghz band
thanks
Message 1 of 3
microchip8
Master
Re: Setting either 5 or 2.4 mghz for devices
Just name the two bands differently? (different SSIDs)
Message 2 of 3
Guru
what actual router do you have? Some can't seperate out the ssids.
Some do have smart connect and it can be disabled.
So knowing what actual device you have is key.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 344 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
