Orbi WiFi 7 RBE973
Reply
Setting for both 2.4ghz and 5ghz frequencies
JenAnne
Follower
Hi. I am having trouble connecting to my work VPN suddenly. It was suggested that I configure the network to allow my laptop to select both 2.4ghz and 5ghz frequencies, rather than defaulting to 5ghz. The suggestion was that further distance from the router may work best on 2.4ghz. Is there a setting on my modem or router that can allow for this?
Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem—DOCSIS 3.1, RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Setting for both 2.4ghz and 5ghz frequencies
For cable modem support and information, please visit and post about this over in the Cable modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Since you list a ORbi RBK53 system, please visit and post about this over in the Orbi AC forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 537 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
