Reply
Setting up VPN for Nighthawk X6 R7900 - Apple Environment
FrankMD
I have recently purchased two of the AC3000 X6 R7900 routers from costco, one for home and one for office.
I loved all feathures, except this one:
   Currently iOS and Android clients are not supported for the openVPN.
Some other customers have had the same concerns since last May or earlier.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Setting-up-VPN-for-Nighthawk-X6-R7900-Apple-...
However, the latest firmware releases only fixed some security issues and ignored this feature.
I need to use my iPad to access the files out of home/office daily, I am hestitating if I should return both devices and find another model.
Any plan to add this feature soon?
Thanks.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 8
LeeH
Prodigy
Re: Setting up VPN for Nighthawk X6 R7900 - Apple Environment
Just wondering if you have tried to connect using an IOS or Android device and failed?
https://itunes.apple.com/us/app/openvpn-connect/id590379981?mt=8
https://play.google.com/store/apps/details?id=net.openvpn.openvpn&hl=en
Message 2 of 8
FrankMD
I tried it at the first place from my iPAD, and the error message shows:
"iOS doesn't support TAP-based tunnels".
I knew that windows using TAP.
Message 3 of 8
Guru
You do need TUN for both Android and iOS.
Message 4 of 8
FrankMD
Hi Stephen,
My understanding is X6 R7900 only supports openVPN with TAP.
Below is the configuration file "client1.ovpn" for windows:
client
dev tap
proto udp
dev-node NETGEAR-VPN
remote xxxxx.mynetgear.com 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
Below is the configuration file "client2.conf" for non-windows:
client
dev tap
proto udp
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
There is no TUN for iOS devices, I guess that is what NetGear needs to add to the router in the future.
Message 5 of 8
JamesGL
Master
Hi FrankMD,
For now, it does not support mobile OpenVPN. I will check if the feature will be available for R7900.
Message 6 of 8
FrankMD
Hi James,
Thanks for your "official" response.
Currenlt Netgear does support the following models for ios devices' openVPN access:
R7000, R7900P, R7800, R9000.
Hope the R7900 will add the feature very soon.
Message 7 of 8
JamesGL
Master
Hi FrankMD,
There are plans to the feature on R7900 but cannot provide you the ETA as to when it will be available.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3072 views
  • 0 kudos
  • 4 in conversation
Announcements
