- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Setting up an AP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Setting up an AP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Setting up an AP
> I am trying to set up a router as an access point [...]
Which model router? Look for "Model" on the product label. Firmware
version?
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Not a router.
> [...] it doesn't seem to be working.
"seem"? "not working" is not a useful problem description. It does
not say what you did. It does not say what happened when you did it.
As usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] Do I need to have an Ethernet cable directly from the modem to
> the ap router? [...]
You need an Ethernet cable (or equivalent) between your _router_ and
your "the ap router". What is your "the modem"? (Hint: If a device
has different types of Ethernet ports, then "connected to device" is not
enough detail.)
> [...] no luck on transmitting an internet signal. [...]
See "not a useful problem description [...]", above.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for a
topoc like "Set Up the Router as a WiFi Access Point".
