Chris_J's avatar
Chris_J
Follower
Nov 29, 2020
Setup WiFi Extender AC1200 EX6110
I hope someone from Netgear reads this.This is a very difficult page to use. My model is not on the list, and I can't delete the Nighthawk bit above. And why does it ask for model number in the Subject box, and again in the next box? What does it mean by Location? Country, city, address, room in the house??
I am trying to set up an AC1200 Model EX6110 wifi extender. After plugging in next to the modem the green power and device lights are on. My list of wifi outlets (on my desktop PC with Windows 10) shows NETGEAR_EXT as 'No Internet,open'. When I enter the recommended webpage (not allowed to put it here) in the brower (several different browsers actually) I just get a general page saying 'You are not connected to your extender's wifi network'. How do I get the  installation page? For information, during all of this I am still connected to the internet via a hard wired connection to the same PC. Any suggestions?
1 Reply
  • > [...] My model is not on the list, [...]
       Try the appropriate forum?:
          https://community.netgear.com/t5/x/bd-p/home-wifi-range-extenders
    > [...] And why does it ask for model number in the Subject box, and
       The Subject is visible to other participants in topic lists.  The
    other (with more details) appears in the posting itself.
    > [...] What does it mean by Location? Country, city, address, room in
    > the house??
       Which do you think would be most useful?
    > [...] When I enter the recommended webpage (not allowed to put it
    > network'. How do I get the installation page? [...]
       Welcome to what may be the worst error message in the world.  For an
    explanation, try (router edition):
          https://community.netgear.com/t5/x/x/m-p/1365830
       Briefly, the idea is that "[www.]routerlogin.net" (or ".com") should
    point to your own router, but that's true only if you use your own
    router for DNS name resolution.  (Or, if the Netgear router can
    intercept your DNS queries.)  Regardless, you should be able to get to
    the thing using its IP address, if you can determine (or guess) that.
    Normally, that would be something like "192.168.1.1" (for a plain
    router) or "192.168.0.1" (for a modem+router), but it could be
    different.  ("10.0.0.1" is a typical alternate, for example.)
       For an extender ("mywifiext" instead of "routerlogin"), which
    normally gets its IP address from (the DHCP server in) your main router,
    you might need to ask that main router which addresses it has granted to
    its client devices.  On a Netgear router, that would typically be in an
    "Attached Devices" report.  (See the router documentation.)
       If the extender is not connected to a router (DHCP server), then its
    default IP address should be "192.168.1.250".
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Find
    Extender's IP Address" or "Cannot Access mywifiXext.net" (remove the
    "X").
    > [...] Any suggestions?
       Here's a radical concept which works for some people:
          https://en.wikipedia.org/wiki/RTFM
    > [...] (not allowed to put it here) [...]
       I'm not sure exactly from what this prohibition is supposed to save
    us.  Nor what makes it a bigger problem than the "routerlogin" names
    which _are_ permitted.  Another Netgear mystery.
