Reply
Should i give up on the 2500/3500 repeaters and get another r7000
d_rick
Tutor
as i'm not making much progress anymore on the repeaters i'm wondering if i should concede defeat on that pursuit and return one of them (will need the other).
if so, then i would likely replace the 2500 with another r7000 and utilize the 3500 for non-streaming applications.
i see 2-3 other people have tried this, and their results are equally as mixed as mine have been.
since NG support has been less than helpful (to be polite), and i've received no responses to the known bug team on r7000 i'm not sure what to do
Message 1 of 3
jmizoguchi
Virtuoso
Re: Should i give up on the 2500/3500 repeaters and get another r7000
Not sure but you think you have active thread similar
http://forum1.netgear.com/showthread.php?t=88838
If same try to use same rather posting multiple of it:D
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
d_rick
Tutor
sorry, this is more of a should i do it, the other one is how would it work if i did. you can delete this one if you want as i returned the 2500 this AM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3426 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
