- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Should the R8000 UI see devices connected via a GS308 switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
In the supplied user interface, on the Basic tab, "attached devices/wired devices" area, should I be seeing any info at all (like status, IP, MAC address) for devices on a connected GS308v2 or is this area only displaying R8000 physical port connectivity?
Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You should see all devices connected to the switch
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Should the R8000 UI see devices connected via a GS308 switch?
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
As long as the switch as after the router.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
cable modem -> R8000 router -> GS308 switch -> devices
This is considered after the router, yes?
I replaced the switch with a new GS308v3, changed to new cables and still can't "see" the devices on the switch.
All devices work fine if I connect them directly to the router but not on the (new) switch.
I assume it doesn't matter which of the 4 ports I use to connect the switch to the router and that it's okay to be using the other 3 ports for other devices simultaneously
And that it doesn't matter which port on the switch that I use to connect to the router?
Either my expectatons are wrong, the router is broken or my connections are wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I don't know what "before" or "after" a router means. It's an
ambiguous nonsense concept. I do know what the WAN side and the LAN
side of a router mean.
If a port on your switch is connected to a LAN Ethernet port on the
router, then things should work properly.
Now, let's move on to actual facts.
> [...] still can't "see" the devices on the switch.
What are these (unspecified) "devices"?
Is your complaint that these (mystery) devices do not _work_ if you
connect them to the switch, or that they work, but don't appear in an
Attached Devices report on the router, or what, exactly?
> switch to the router [...]
Any one of the four router LAN ports should be fine for the
connection to any one of the switch ports.
> [...] and that it's okay to be using the other 3 ports for other
Yup.
Now it's my turn. _I_ assume that these devices have some kind of
LED port-status indicators, which only one of us can see. Care to share
the enlightenment? Have you tried swapping cables?
Your expectations seem ok. If a router LAN port works with an
individual device, then it should work with a network switch. A bad
switch could cause problems for a device which is connected to the
switch. I can't see your "my connections". But some of this sounds
strangely familiar.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
That's right. After all, you are asking the router to tell you what is connected to it.
Out of interest, but possibly relevant, what is this cable modem? Make and model?
So, none of the devices that you add to the network through the new switch will work? Is that also the case for the old switch? Invisible and not working?
I ask because earlier on it was the invisibility that troubled you. Now it is that and the fact that they also don't work.
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
> That's right. [...]
It's "right" if you start ar your ISP, and count toward your own
computer. Obviously, it's the opposite if you start at your own
computer, and count toward your ISP. I'm unaware of any industry
standard, or any reasonable rationale, which says which way you should
view your network. (But I'm always open to enlightenment.) Hence:
Think about it. If you can.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The cable modem is a Cisco DCP3008.
Sorry if I misled about "can't see/doesn't work". None of the devices on the switch are accessible via the network. But the type of devices made that difficult for me to prove to myself. A webcam's propriety software is unable to find the device, I'm unable to map a NAS, and I dont have access to the Dlink router installed by the security company to confirm connectivity. So I moved went from a lack of proveable functionaly to trying to "see" they were even connecting to the network by checking the router UI.
But I may have found the problem. I removed all the cables fron the switch and reconnected them one at time, stopping to check the wired device status on the router UI. This first device I connect did appear on the wired devices list and the 2nd one did too. But when I connected the 3rd device, they all disappeared from "wired devices".
I'm guessing the chances of a new cable failing in the same way as the one it replaced is highly unlikely but that appears to be what's happening. I'll leave it disconnected until I can get a new cable and will monitor to ensure all is well.
Thank you your help and for being respectful while I thought this through.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@antinode wrote:. But some of this sounds
strangely familiar.
https://community.netgear.com/t5/x/x/m-p/1927787
Good memory. I know it's not easy being the sensei and having a never-ending stream of idiotic people appear here to ask the same idiotic questions but I had to bail on that thread.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If that is the DPC3008 then that rules out some possibilities.
You seem to have homed in on the problem.Good research Sherlock.
You can narrow it down to the cable, and rule out the devices, by testing the third device with one of the other cables.
Maybe you did that.
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@michaelkenward wrote:
@OneJoe2 wrote:The cable modem is a Cisco DCP3008.
Yes .. DPC3008 .. typo.
The location of the third device is farthest from the switch and I have no "known good" cables that long. But I might unmount the device and bring it closer or just wait to get a cable that I can always use.
Again .. thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If possible, you could take another, more portable, LAN device to the remote end of the cable and see if that works.
Or disconnect and move the cable and use it to connect known good devices.
You will kick yourself if it turns out to be something other than the cable.
Again, maybe you tried this.
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I replaced the long(ish) cable and all is fine now.
All devices on the GS308 are doing their thing on the network and I can see them all as "wired" devices from the R8000 'basic,attached devices' and 'advanced, security, access control" displays.
Thanks lots for all the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
That's good. Now you have a high quality clothes line to dry the washing.
Just another user.
