Discussion stats
  • 3 replies
  • 287 views
  • 0 kudos
  • 4 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Showing I got internet but it won’t connect to WiFi
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Highlighted
Re: Showing I got internet but it won’t connect to WiFi
Can you explicit what is your router?
Message 2 of 4
Highlighted
Master
Looks like it is R8000 from tag id on the bottom of the posting.
Is this correct and what you mean the router has no wifi signal or what ?
Message 3 of 4
Highlighted
There is a manual and support stuff for the R8000 somewhere at the end of this link:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
That's about the only help anyone can give unless you tell them what is happening. Here is the information that the forum suggests that you provide:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
