Reply
Signing in to my Router
RJGula1952
Follower
When I went to Type http://www.routerlogin.net or http://www.routerlogin.com , I get the following:
The connection was reset
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
What can I do to get access to my Router ?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Re: Signing in to my Router
Did you find this?
If you cannot login to your router | Answer | NETGEAR Support
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6267 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
