- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow Output N750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Slow Output N750
I have my N750 connected by Cat 5 cable to Comcasts Arris Surfboard modem.
I use it for wifi through the house as the Comcast modem is in a poor location at corner of house.
If I plug the cable directly into my laptop I grt 650 Mbps. dowm.
If I plug the cable into the N750 and then plu my laptop into the N70 's ethernet port I only get 50-80Mbps.
Wireless speeds on the N750 are also only 30-50MBPS.
I have done a factory reset and nothing changed.
Why are my output speeds so slow?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow Output N750
What is the model# of the ISP modem?
Try changing to CAT6 LAN cables.
Ensure your ethernet adapter is connecting at 1000Mpbs and not at 100Mpbs.
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
