Reply
Slow WiFi on R7800
unknown31456
Follower
Slow WiFi on R7800
brief rundown on the set up and situation:
modem -Arris surfboard SB6183 says its cabable of handling speeds of 500+
internet speeds of up to 100gbs
direct connect to modem i get 80+ with mulitiple devices connected. I have the newest firmwear update on the router, QoS is off, traffic meter is off, along with having my settings for WiFi for my laptop turned to highest priority. Along with already resetting all equipment, before tests are done. On the netgear router login the WiFi is reading at a speed of 100+ download rate. I'll do a speed test with the laptop at the time its the only thing that is conneted to the WiFi but still gets a consistant 20 mbs rate. What gives?
Also I'm but inches away from the router.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
duckware
Prodigy
Re: Slow WiFi on R7800
On your wireless device, at the time of the problem, what is the PHY speed of the wifi connection?  See duckware.com/wifi#PHY for help on finding that.
Do you believe your wireless device is connected to the 5 GHz band SSID?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 306 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
