Reply
Slow Wireless Throughput R8500
Barfanugen
Hi All,
Ok I bought a new R8500 from Best Buy and I cannot get the wireless throughput to match previous router or come even close to my ISP UL/DL rates.  Netgear said it was a bad router and I took it back to get it exchanged.  I am having the same issue with the new router, I do not belive the first was bad now.
Information:  ISP-GVTC, UL: 100 MB and DL 500MB.  Directly into the ISP I see 498 DL and 101 UL.  Wired ethernet performs as expected.
I've read many articles in the community that require parameter changes that fix the issue.  I've turned off all that are mentioned in the below discussion and this did not work.  https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Nighthawk-R8500-slow-on-Cox-GigaBlast/m-p/11....
This is not a channel issue, nor poor RF Conditions.  Test were performed at -35dBm with the next best server at -90dBm.  Changing channels did not have much change at all, this has to be a setting issue.  I am stumped.  Where can I find the solution?
I've ran all tests on firmware V1.0.2.64_1.0.62 which was right out of the box, in addition I ran the exact same tests on V1.0.2.80_1.0.71
I tried to toggle on and off Traffic Meter, QOS, UPnP, and WMM.  See below, not much difference in the speeds.
  1. Firmware Version (Right From Box) V1.0.2.64_1.0.62
Traffic Meter: Off
UPnP: On
QOS: Off
WMM: On
Wired: DL 485Mbps, UL 99.8Mbps
2.4: DL 77Mbps, UL: 86 Mbps
5.8_1: DL 183 Mbps and UL 98.9 Mbps
5.8_2: DL 159 Mbps and UL 98.7 Mbps
Traffic Meter: Off
UPnP: On
QOS: On
WMM: On
Wired: DL 479.48Mbps, UL 96.68Mbps
2.4: DL 62Mbps, UL: 85 Mbps
5.8_1: DL 175.34 Mbps and UL 96.6 Mbps
5.8_2: DL 198.76 Mbps and UL 85.6 Mbps
Traffic Meter: On
UPnP: On
QOS: On
WMM: On
Wired: DL 178.2Mbps, UL 96.68Mbps
2.4: DL 70.6Mbps, UL: 86.44 Mbps
5.8_1: DL 148.12Mbps and UL 97.08 Mbps
5.8_2: DL 133.34Mbps and UL 96.01 Mbps
  1. Firmware Version 1.0.2.80_1.0.71
Traffic Meter: Off
UPnP: On
QOS: Off
WMM: On
Wired: DL 485 Mbps, UL 99.8 Mbps
2.4: DL 44.62 Mbps, UL: 86.23 Mbps
5.8_1: DL 170.6 Mbps and UL 98.5 Mbps
5.8_2: DL 177.71 Mbps and UL 88.75 Mbps
  1. Firmware Version V1.0.2.80_1.0.71
Traffic Meter: Off
UPnP: On
QOS: On
WMM: On
Wired: DL 482.48 Mbps, UL 97.3 Mbps
2.4: DL 50.21 Mbps, UL: 85.43 Mbps
5.8_1: DL 200.04 Mbps and UL 96.6 Mbps
5.8_2: DL 159.62 Mbps and UL 86.6 Mbps
Traffic Meter: On
UPnP: On
QOS: On
WMM: On
Wired: DL 183.25 Mbps, UL 96.88 Mbps
2.4: DL 49.4Mbps, UL: 84.36 Mbps
5.8_1: DL 156.9 Mbps and UL 96.2 Mbps
5.8_2: DL 134.09 Mbps and UL 96.74 Mbps
Thanks for all your help.
Ray
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 4
Retired_Member
Not applicable
Re: Slow Wireless Throughput R8500
You should contact support via mynetgear and open a case also be mindful of the return period incase NG takes their time hoping you wait until you cannot return for refund. I have a case and I'm still waiting for a fix. I'm on my second router too!
                                       Do not give up your power to return it.
Message 2 of 4
Barfanugen
Excellent idea, thanks.
Ray
Message 3 of 4
ElaineM
NETGEAR Employee Retired
@Barfanugen Feel free to give us any update once you have contacted support.
ElaineM
NETGEAR Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2344 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
