Reply
Slow connection from GS108Ev3 to R7800
bpaskin
Hi All,
The issue I am facing is slow speeds from my switch to the router.  Computer to computer testing with iperf3 shows 940+ mbs through the swtich.  Speed testing from the router to the modem to speedtest.net gets me around 880 mbs.  Test from a computer and plug it into one of the available router ports also nets me around 850+ mbs.  However, testing a computer through the switch to the router to speedtest.net gets me slightly below 300 mbs.    Any setup I may be missing on the router side?
Router: R7800 with V1.0.2.32 firmware.
Swich GS108Ev3 with  v2.00.12 firmware.
All cables are CAT6 and have been tested.
Thanks,
Brian
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 2
Re: Slow connection from GS108Ev3 to R7800
Answers here may point you in the right direction:
>>> R8500 only getting 200MB download through LAN with... - NETGEAR Communities <<<
In essence, you are not alone. Try searching around the archive here for messages on similar lines.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1417 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
