Reply
Slow internet speeds
atcconductor
I have 1,000 GB speed through my internet provider but am only getting around 350 GB wifi speed on my router. Any suggestions for improving the speed is appreciated.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 4
Accepted Solutions
Guru
Re: Slow internet speeds
If you're hitting 350mbps, you're actually doing pretty decent with the r7000.
Actual testing of AC1900 devices show around that speed.
https://www.smallnetbuilder.com/wireless/wireless-reviews/32239-ac1900-first-look-netgear-r7000-a-as...
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 4 of 4
All Replies
Guru
You won't hit gigabit speeds over wireless AC.
You'll only hit gigabit speeds over wired or over an AX router (decent one, not cheap) and AX device.
What router are you using?
How far from the router is the usb device?
Message 2 of 4
atcconductor
Using Model R7000 and router is just below, less than 3 feet from tv.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 451 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
