TobyMiles
Jun 26, 2017Follower
Slow internet with Nighthawk R8000 using a DM200 Netgear Modem
Hi, I installed a R8000 Nighthawk X6 AC3200 Smart WIFI Router with a High-Speed DSL Modem (Model DM200) to replace a BT Homehub, and I seem to be getting slower internet. Help would be appreciated, thank you.
- JamesGLNETGEAR Employee Retired
Hi TobyMiles,
If the computer is directly connected to the modem is the speed faster? If yes, try to set the DM200 to bridge mode.
https://kb.netgear.com/30773/How-to-set-DM200-into-bridge-modem-only-mode
The DM200 is a 100mb max modem what was the internet speed you had before and what internet speed you have now?
Here is the manual for the modem http://www.downloads.netgear.com/files/GDC/DM200/DM200_UM_EN.pdf
The R8000 router should be able to handle upto a 1gb connection but the modem will not.
Hi TobyMiles,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
