Reply
Slow speed on my r9000 using 2.4ghz
rudgo
Got a brand new r9000 nighthawk x10 did a speed test on 2.4ghz and its like 2mb down and 0 up on 5ghz i am getting 180 down and 12 up. I tried changing the channels on the 2.4ghz but still very slow with my old nighthawk r8000 i was getting 45 down and 10 up with 2.4ghz. I did a factory reset but still did not fix the issue. Any help i would appreciate it
thanks
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
Re: Slow speed on my r9000 using 2.4ghz
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
Did you swap this router out for something else?
If so, to get the modem, whatever that is, to forget settings from the old router, you need to reset the whole network and set up from scratch. And do things in the right order.
Read all about it in the QuickStart Guide:
There is a manual for the R9000 somewhere at the end of this link:
>>>> Nighthawk X10 R9000 | AD7200 Smart WiFi Router| NETGEAR Support <<<<
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
rudgo
I swap out my r8000 with a 9000 i reset the modem and added the router updated the firmware still at 2.4 ghz i am getting like 2mb down i think i will send it back my old router the r8000 when i put that back all works good
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 601 views
  • 0 kudos
  • 2 in conversation
Announcements
