Reply
Slow speed suddenly on R8000
dimab0
Follower
I've been using this router for about 1.5 years now. As of 2 days ago, my download speed seems capped to 7Mbps, while the upload goes up to 20Mbps. Directly through out wired connection in the wall, not using the router, I am getting 200 / 200 Mbps for down and up.
What can I troubleshoot? Nothing has changed at all this week. I have tried to unplug and plug back in the router, but there is no effect. I did a hard reset and used default router settings and still get the same effect. Is there anything else to try? I can't believe that I suddenly have a broken $300 router....
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: Slow speed suddenly on R8000
Hi dimab0,
1. What is the firmware version of the router?
2. Disable QoS and check if the same.
3. Use a different ethernet cable.
Message 2 of 3
All Replies
JamesGL
Master
Hi dimab0,
Message 2 of 3
JamesGL
Master
Hi dimab0,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5347 views
  • 0 kudos
  • 2 in conversation
Announcements
