Reply
Smart Connect won't turn on
captgadget
When I try to turn on Smart Connect I get an error message I have different settings for 2.4 & 5. Well I look at the SID and the passwords and they are the same so I click apply. It changes the settings but then the 5GHZ is grayed out in the box with a check mark and when I check my iPhone 5ghz is not showing up on it or any of my devices.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 5
microchip8
Master
Re: Smart Connect won't turn on
Which router model? Which firmware version?
Also, Smart Connect on NG routers is fundamentally broken and causes only issues. Most keep it disabled
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.84SF
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 5
captgadget
V1.3.1.64_10.1.36
Message 3 of 5
microchip8
Master
That's an USB adapter, not a router
Message 4 of 5
captgadget
how about a r700p then?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 417 views
  • 0 kudos
  • 2 in conversation
Announcements
