Reply
Smartconnect on C7800?
charleyrich
Is there a way to use SmartConnect on the C7800 Router/modem?  I don't see it in the config screen when I log into the router.
I tried the app Genie, but I don't see it there.  The app NightHawk says it doesn't support this model.
I have manually set both the 2.4 and 5 netowrks to the same SSID.  Should I expect any unexpected side effects of that?
Thanks,
Charley
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: Smartconnect on C7800?
Please try to only post 1x.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Smartconnect-on-C7800/m-p/2023324/highlight/...
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 199 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
