Reply
Smartconnect on C7800?
charleyrich
Is there a way to use SmartConnect on the C7800 Router/modem?  I don't see it in the config screen when I log into the router.
I have manually set both the 2.4 and 5 netowrks to the same SSID.  Should I expect any unexpected side effects of that?
Thanks,
Charley
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: Smartconnect on C7800?
the C7800 doesn't have smart connection.
You can set them with the same ssid but devices won't roam between the 2 bands.
I'd seperate them out (different ssids) so you can choose which band to connect devices to. For example media streamers, gaming, etc need more bandwidth and should be on the 5ghz.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 233 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
