Orbi WiFi 7 RBE973
Reply
Some Dutch translations aren't shown correctly when the Netgear R7000 is found in Windows Explorer
Wiens
OS: Windows 10 64-bit NL-NL
Model: Netgear R7000
Firmware version: V1.0.7.6_1.1.99
Language GUI interface version: V1.0.7.6_2.1.38.1
Some Dutch (NL-NL region) translations aren't shown correctly when the Netgear R7000 is found in the Network Infrastructure in Windows Explorer:
- The string  "inschake" isn't fully visible as "inschakelen", see Figure 1A (This bug exists in Windows 8.1 and Windows 10, NL-NL region);
- The string "uitschak" isn't fully visible as "uitschakelen", see Figure 1B (This bug exists in Windows 8.1 and Windows 10, NL-NL region);
- The string "Verwijderen" in both contextmenus is disabled and hasn't have a meaning in the contextmenu.
Other Netgear routers may be impacted with the same Dutch (NL-NL) translation issues. It is not a Windows string. The string activates when the router is connected.
Figure 1A:
Figure 1B:
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
Wiens
Re: Some Dutch translations aren't shown correctly when the Netgear R7000 is found in Windows Exp...
I have tried a router from a different vendor (Sitecom WL-309). It looks like the translation issue is not caused by the Netgear or Sitecom router, but it is a Windows 10 translation issue. I have notified the Microsoft about it in the Feedback-hub App.
Also "Network Map" is not translatied into Dutch, see screenshot below:
Message 3 of 4
All Replies
JamesGL
Master
Hi Wiens,
If you connect the computers to a different router will it shows complete translation?
Message 2 of 4
Wiens
Message 3 of 4
JamesGL
Master
Hi Wiens,
I am glad you were able to find the culprit. Continue to work with microsoft for resolution.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2432 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
