Reply
Speed issues on the R8000 Nighthawk
sprasad_it
So I recently purchased the R8000 Nighthawk X6 AC3200 - On day one since my bandwidth from my provider is 300 Mbps down and 300 Mbps up - I did get almost the same speed on my devices which are on Wifi on the 5ghz channel and near the router,
However next day onwards this dropped to 175Mbps up and down although in the admin panel under Dynamic QoS the speed test shows 297.88 Mbps 308.79 Mbps
So I opened a support ticket and I was asked to install the following update R8000 Firmware Version 1.0.4.56 - Hot Fix (https://kb.netgear.com/000061990/R8000-Firmware-Version-1-0-4-56-Hot-Fix)
My question is "Will this resolve the speed issue i am having on my devices?" as doing a beta firmware update means I need to do a factory reset and redo all the settings again... I have backed up the settings but its still feels like a pain to do if this doesnt resolve my speed issue.
Any help would be most appreciated.. Thank you
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Accepted Solutions
sprasad_it
Re: Speed issues on the R8000 Nighthawk
Found the answer - Just disabled Dynamic Qos
Message 2 of 3
All Replies
sprasad_it
Message 2 of 3
Beat me to it.
QoS is useless at 300 Mbps. You don't need it. Just slows things down.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1568 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
