- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Speedtest question
- Mark as New
- Bookmark
- Subscribe
- Permalink
Speedtest question
I have both a Netgear Router and Modem. What does the Speedtest on the Nighthawk App test. That measures about 300 MBPS but when I check speed on computer sitting beside the router speed was about 70. Do I have a problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Speedtest question
It looks at the speed that the router sees on your Internet connection.
....when I check speed on computer sitting beside the router speed was about 70.
Tested how? Wifi? Wired?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was Wifi. But I was very close to the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wifi speeds are never as fast as wired. They also depend on many factors, not least the capabilities of the client device. Some clients can never do much more than 70 Mbps. They are designed like that.
Does this device perform a lot better when you try it with other wifi sources?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the responses. It really is not a speed issue. I have had issues with losing connection almost daily. The speed issue came up on a support chat with Xfinity where the rep commented that 70 was low for my service. That made me feel something was wrong with the Modem (the Router is newer is why I assumed Modem issue). So I did buy a new modem that does better siupport my service. But I have not noticed any speed issues (before or after new modem) - I was looking for solution to dropping internet connection. And it still is an issue.
I work from home through a VPN and it was odd because I was still able to stay connected through VPN but was not able to connect to websites (other than Google.com). My IT person at work set up a routine for me to ping router and server at work. And I could do both succesfully while unable to connect to websites.
So I thought the speed drop through the router might be indicative of a problem causing my connection failure. And Xfinity support was no help.
