Orbi WiFi 7 RBE973
Reply
Stable firmware recommendations for R7500v2
DGallo
Tutor
Hello. In your experience, which firmware is the most stable for the AC2350 R7500v2 router? For me the most stable has been 1.0.3.26, but it's quite old and have some vulnerabilities. Later versions have shown issues (mainly connection drops when several concurrent video meetings).
I've tried latest DD-WRT releases (latest being r45849 02/25/2021) but have some issues specially with 2.4GHz band. Not tested OpenWRT or other firmwares yet.
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 1 of 6
Reverse
Guide
Re: Stable firmware recommendations for R7500v2
In reply to your response I found any firmware to my r7500v2 above 1.0.3.38 starts to drop connection and disconnect from my Internet without giving any errors. I think NetGear deliberaly trashed the firmware forcing users to buy newer NetGear wifi devices. I think this is their plan to force users whom find working hardware to fail them so they are forced to upgrade. I know this because I even tried their latest firmware and within hours connections gets dropped for no reasons. So when I forced downgrade to 1.0.3.38 all connections came back and no dropped connections. Overtime I have to restart the router but beyond that ever since .38 update I had no issues with internet or ISP. So this comes down to NetGear delibrarly trashing a good router to make people think something is wrong and buy a new router. So if your trying go only up to 1.0.3.38 and stop there.
Message 2 of 6
Wypc307
I have had pretty good luck with dd-wrt r44719 std (11/04/20)
Message 3 of 6
Reverse
Guide
LINK???
Message 4 of 6
DGallo
Tutor
After my original post I researched and have been using the OpenWRT stable version from link below:
https://forum.openwrt.org/t/ipq806x-nss-build-netgear-r7800-tp-link-c2600-linksys-ea8500/82525p
Message 5 of 6
Guru
Please continue to post in the 3rd party FW forums as they will have more information and support regarding there FW. This forum is for NG's stock FW.
Thank you.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1727 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
