Orbi WiFi 7 RBE973
Reply
Standard wifi remain active
Majid_Aldossary
Follower
Hi There,
I installed my new X8 this morning and been struggling for few hours now trying to deactivate the standard wifi.   The first time I started the router it came with 3 standard networks 1x 2.4 and 2x 5G.   in Genie when I changed the SSID in the router settings  it changed it for the 2.4 and one of the 5s.  the 3rd one (NETGEAR85-5G) remained active with the old (standard password).   Im not able to find a way to change or deactivate it.
Will greatly appreciate your support,
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 3
Accepted Solutions
Retired_Member
Not applicable
Re: Standard wifi remain active
If you're referring to the Genie App and using that App DON't. Login and use WEB GUI.
Message 3 of 3
All Replies
netwrks
Master
If you haven't already, upgrade to current firmware, reset to factory default, and reconfigure.. firmware
Message 2 of 3
Retired_Member
Not applicable
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2009 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
