Reply
Highlighted
Follower
Streaming Music - Ext Hard Drive - R7000
Hello – Have the R7000 with and external hard drive attached via USB. On iphone and android devices, I am able to stream music over wifi using apps off of each devices app store.
I would like to stream over 3G/4G when away from wifi. Is there any way to do this on devices and NOT use the VPN setup via a PC?
Message 1 of 2
Highlighted
Virtuoso
Re: Streaming Music - Ext Hard Drive - R7000
It will be limited other than open port if any streaming server you installed on pc can do that . Otherwise you have to access as an file using ftp, http.
VPN (OPENVPN) feature come with R7000 might be simpler and secure
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1658 views
  • 0 kudos
  • 2 in conversation
Announcements
