Orbi WiFi 7 RBE973
Reply
Suggested Replacement for Verizon Fios Router
Mike_L299
Follower
Looking for a suggestion for a good replacement for my FIOS router.  Would I need a Moca adapter with your suggestion.
Looking for about $200.
Thanks
Message 1 of 2
Guru
Re: Suggested Replacement for Verizon Fios Router
I don't know of any Netgear devices that currently support moca.
Also, you need to make sure verizon will have an ONT at your locatio of if the gateway is needed or not
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 415 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
