- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Switch Use and maximizing performance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. I am a novice at network setup. I currently have a Netgear CM2050V modem connected to a Nighthawk AX12 RAX200 router in my home. Speeds are around 600Mbps.
I ran a Cat 5 cable via underground conduit to my garage and inlaw apartment. I have a Netgear GS108 unmanaged switch in the garage with is connected to two PoE security cameras and one Nighthawk R9000 router in the apartment. Speeds in the apartment are quite a bit slower and the cameras drop off line from time to time.
Can anyone tell me if I need a managed switch and how to configure the modem and both routers for maximum performance? I have the AX12 RAX200 router plug into the 2.5G/1G port going to the switch in the garage. The modem indicates 2.5 Gig traffic and the RAX200 port to the garage indicates 1 Gig traffic, but the R9000 router is operating slow.
Any ideas? Thanks for any advice.
Pete
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Switch Use and maximizing performance
How far?
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
35 feet is no distance. Well within the standards. So it should work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not have an ISP modem/router. Using all my own equipment. Netherworld CM2050V modem and Nighthawk RAX200 router in the house. The in-law apartment 35 feet away has a Nighthawk X10 R9000 router. Any problems with this setup? I also have a GS108 switch connecting both routers via an Ethernet cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@PPMACK wrote:
I read the article about double NAT. Very interesting.
If one of the routers is not set as an Access Point (AP) you're still in a double NAT situation, regardless of how you connect them with eachothers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. As @microchip8 says the same thing applies. That is why I mentioned it. Your description screamed out trouble.
It doesn't matter what the network has at the front end. It is the dual router thing that causes confusion.
