Orbi WiFi 7 RBE973
Reply
Telnet console checkbox
4wayhandshake
Follower
In what f/w revision did Netgear remove the Telnet checkbox from the R9000's http://routerlogin.net/debug.htm?
I'm guessing this was removed for security reasons.
Is there some way to get it back, besides reverting to an older f/w?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: Telnet console checkbox
> In what f/w revision did Netgear remove the Telnet checkbox [...]
   I don't know.  You could try reading the firmware Release Notes
documents, but they tend to be nearly information-free.
   Perhaps.  Or an error or oversight.  With the usual documentation,
it's tough to do more than guess.
   You might explore the HTML, and see if something on that page has
been commented out in an easy-to-restore way.  I do little of that, so I
know nothing, but I believe that Firefox has a whole bunch of stuff
under Tools > Web Developer.
   Have you tried one of the Telnet Enable tools floating around out
there?  I use the program which I modified: http://antinode.info/nte/
   The feature has apparently been gone from the R7000 for a while.  I
don't recall seeing any reports of improvement or work-around on that
model.
      https://community.netgear.com/t5/x/x/m-p/1786837
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 552 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
