Reply
Terrible Bandwidth Throughput
EastonCo
Hello all,
I purchased a Nighthawk R7900P router back in August 2017 and I am having serious issues with it being able to handle my 1Gbps download speed. Directly from my modem I receive nearly 1Gbps, yet through the Nighthawk, hard wired with CAT 7 STP I am only getting up to 600Mbps. The router is not performing well at all, giving 50-60% throughput. Is this a problem with all of these nighthawks? Does anyone else have a 1Gbps connection?
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 5
schumaku
Guru
Re: Terrible Bandwidth Throughput
Curent firmware (1.0.2.10 -> https://www.netgear.com/support/product/R7900.aspx#download) in place?
QoS disabled?
Message 2 of 5
EastonCo
Current firmware is V1.3.0.10_1.2.2, QOS is disabled.
https://www.netgear.com/support/product/R7900p.aspx#download
It's the R7900P.
Message 3 of 5
Guru
Try a factory reset on the router and configure wifi only. Don't enable or configure QoS, Traffic Meter or Access controls. Run a quick speed test. Try different browsers like IE11, FF or Opera.
What is the mfr and model # of the ISP Modem/ONT?
@EastonCowrote:
Hello all,
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 4 of 5
EastonCo
I have done this as well. From some peoples articles I have read, it seems like this is an issue with the router firmware. When I use a different router and the R7900P as just an access point, I get full speeds. When the R7900P is responsible for the routing, however, I loose 30-40% of my bandwidth.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 528 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
