Reply
Too Many Devices?
andrewjets
Too Many Devices?
My "Smart" Home is running upwards of 60 devices, quite often devices such as Roku, Arlo Cameras, Ring Devices, etc drop off line contsantly. Additionally, many IOS Devices will connect to the router but say "No Internet Connection". My home PC will warn "IP address could not be Configured" I will reset the router and cable modem, then it will work for a while until devices start dropping off. Do I have too many devices? Do I need a second home network? Thanks
Model: EX7000|AC1900 Nighthawk WiFi Range Extender, R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 3
microchip8
Master
Re: Too Many Devices?
Which router model?
Which firmware version? (not "the latest")
Is Smart Connect enabled?
Max WiFi devices per band is 32 for NG routers. And even then, you're pushing it
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.91.1SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 3
andrewjets
Firmware is V1.0.2.68
I had turned off smart connect because several of my devices wont work on 5.0
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 498 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
