Reply
Trouble upgrading firmware R6220 1.1.0.34 to 1.1.0.100
tlawson71
Follower
I cannot get the firmware updates to download from the Genie page and when I download it as a dmg it cannot be opened on my Mac. Any help would be much appreciated.
Model: R6220v2|AC1200 Smart WiFi Router with External Antennas
Message 1 of 2
Guru
Re: Trouble upgrading firmware R6220 1.1.0.34 to 1.1.0.100
When you download it, you don't "open" it. You extract it. then you have to upload it to the router using the manual firmware update process.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 102 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
